I'ld like to use the RPM-Telemetrie with my new RAW 420. The direct drive motor has 42 poles. Unfortunately it's not possible to set the telemetry settings of the Spirit-Software to 21. What can I do?
Kind regards
Tanja
SAB Goblin RAW 420: Telemetry Motor
Dudemeister
It's strange. You can enter 21 in the sensing divider in in the governor settings, but not in the Telemetry section. Your input in the governor section end up being divider 14 and ratio 1.0 in the telemetry section.
Have you tested it to see what the telemetry values are like? It would either show correctly, or it would show nearly double the actual RPM.
What about faking it, by that I mean set it to something like 10 and 2.1. If it responds correctly, the RPM values should be the same as 21 and 1.0
