Way to hit below the belt.10x wrote:Just make sure the main board is not too close to the speaker.....
Spirit Wave discussion
curmudgeon
Seems that Nick Maxwell will launch a new FBL paired with new transmitter and new servos. From what I gathered, they will be manufactured by JR Propo.
https://www.helifreak.com/showthread.php?t=928859
curmudgeon
As I best understand it, Nick currently flies his own flight controller, and plans to eventually release it, but this controller will NOT be produced by JR at all. This Nick Maxwell flight controller will apparently integrate very well with existing JR radios, similar to Spirit and Jeti (as well as other radios), but I would be very surprised if this integration can match the seamless integration of VBC/Neo or the expected integration between WAVE radio and Spirit units.vvv850 wrote:Seems that Nick Maxwell will launch a new FBL paired with new transmitter and new servos. From what I gathered, they will be manufactured by JR Propo.
From the latest RCHN podcast, it seems that JR will be building the hardware, and Maxwell the software side. Using "XBUS" from FBL to servos also.curmudgeon wrote:As I best understand it, Nick currently flies his own flight controller, and plans to eventually release it, but this controller will NOT be produced by JR at all. This Nick Maxwell flight controller will apparently integrate very well with existing JR radios, similar to Spirit and Jeti (as well as other radios), but I would be very surprised if this integration can match the seamless integration of VBC/Neo or the expected integration between WAVE radio and Spirit units.vvv850 wrote:Seems that Nick Maxwell will launch a new FBL paired with new transmitter and new servos. From what I gathered, they will be manufactured by JR Propo.
curmudgeon
Yes. That’s what I understood as well from the podcast interview. It should be interesting.vvv850 wrote:
nichtdiemama
When do we get detailed information abaout the wave? And when is it possible to see the manual?
I cant wait to see this radio.
Greetings Jens
Greetings Jens
Later tomorrow many details will be revealed.
