Yes, all simulators are supported by plugging to your computer. It will simply work.
But there will be more news to be revealed...
Spirit Wave discussion
morrolucky
How about connecting via wifi?ZeXx86 wrote:Yes, all simulators are supported by plugging to your computer. It will simply work.
curmudgeon
When is the Spirit WAVE radio expected to be in stock for sale?
nichtdiemama
How would it be make a small USB receiver for simulators. The wire can be annoying sometimes.
For sure it can work by Wifi or bluetooth. Technically there is no problem.
Latency could be acceptable. We will see if this feature will be added before release.
curmudgeon
I believe he means how the VBC Touch radio and Heli-X in the computer connect WIRELESSLY over WiFi without needing any additional hardware.vvv850 wrote:You should be able to just plug it in the PC via usb C and it will work as Jeti does.
This is the smallest thing we could add and not only with Heli-X but all simulators.
morrolucky
Will it be a software emulator (WiFi > joystick)?ZeXx86 wrote:This is the smallest thing we could add and not only with Heli-X but all simulators.
