First of all, thanks a lot for the recent update of Spirit Aero to 1.7.0 that now supports Crossfire protocol!
Now my question is: Am I trying to make something work that is not supported?
I am talking about main battery pack telemetry from my Hobbywing Platinum 40A V4 through Spirit2 Aero —>TBS Crossfire RX Diversity Nano —> Radiomaster TX16S + TBS Crossfire TX Micro.
I have thoroughly followed your two integration guides for Spirit-Hobbywing and Spirit-Crossfire:
https://manual.spirit-system.com/index. ... _Telemetry
https://manual.spirit-system.com/index. ... sFire_CRSF
The Spirit2 and Crossfire are talking servo control signals to each other, but unfortunately no esc telemetry like main battery pack voltage/percent or rpm that is supposed to come from the HW V4.
- Hobbywing esc firmware 4.0.0.0. (none VBar)
- Telem cable from esc progport (without red wire) to Spirit2 Sat1 port
- Trottle cable from esc to Spirit2 Aux1 port.
- Spirit Aero Firmware 1.7.0 (same telemetry setup is also not working on Heli 3.5.0)
- Set General Receiver Setting to Crossfire CRSF.
- Set Advanced Setting Telemetry to Hobbywing V4
- Crsf cable from Spirit2 Rud port to tbs rx nano diversity power+out port 1
- Crsf cable from Spirit2 Ail pin to tbs rx nano diversity out port 2
- Crsf firmware 6.19 (latest ver) on both rx and tx.
May any of you please confirm that Spirit2 supports Hobbywing telemetry to pass all the way through Spirit2 and crossfire rx to crossfire tx or not?
Best regards.
Hobbywing V4 Main Battery Telemetery and Crossfire?
Hi cycled
I am also diving into ELRS-equipment these days (have now got tx16s/ranger micro/mateksys ELRS-R24-P6) Your ER6 seems interesting and is equipped pretty similar to the mateksys that I just got. At least it seems like they both have main battery sensor (Vbat on matek, Ext-V on ER6) According to ER6 manual the ER6 Ext-V input can sense up to 35V meaning you should not need that telemetry data from you esc through Spirit2 to get main battery voltage. Anyways, our question to Spirit remains the same: How can we make Spirit2 fbl pass through telemetry data sent from Hobbywing V4?
Don't know; I suspect CRSF isn't implemented in Spirit yet.
The ER6 works with CRSF out (probably also SBUS/SUMD but didn't test; those modes don't support telemetry yet). It's a nice receiver except that the only possible serial output is via a tiny connector on the back; you can't use the PWM pins. I am informed that you can on the ER6G. Otherwise maybe the Matek R24-D is a good choice for ELRS.
Matek R24-P6 can be set up with serial -> SBUS on hardware port2 in the elrs configurator. Matek R24-D needs the hardware converter from crsf to sbus, but I could not make that one work correctly. Therefore the setup on my heli is now the Matek P6 with SBUS on port2 to the fbl and the Vbat pad on the Matek attached to the lipo 6S which sends main voltage back to the tx. Works on the bench, haven’t tested in real life yet.
@slendrian did you try recently? Because ELRS 3.3 supports SBUS and SUMD outputs.
Wow, thanks a lot for the update:
«PWM receivers can also be configured to output serial on some pins and select serial protocol, so now you can have CRSF/SBUS etc and PWM simultaneously!»
ELRS is unbelievable! Actually I need the three protocols straight away on a home made drone, so this is good news.
