Spirit GTR mit Geo-Link: Absturz mit Höhenrettung
Dr.Fleming
ok, bist du invert geflogen ?
toni67 wrote:
Dr.Fleming wrote:Welchen Rettungs Modus hast du aktiviert !
Normal.
Siehe 1. Post
deleted !
Tanja
Hello together and thank you very much,
ZeXx68:
No other features were engaged. Only altitude limit. I'm not using different banks.
The vibrations are not very low. Please have a look on the attached chart.
Franz88:
For channels please have a look on my first post. It's attached. All Channels are from -100 to +100 (Jeti). The altitude limit (channel 14) is activated with +100 in radio and Spirit, deactivated with -100.
all others:
Yes, it was normal mode. So the heli should have to rescue with base downwards in every case. But the heli turned upside down in the moment of rescue by itself.
Kind regards
Tanja
Tanja
Rebuild after crash
Tanja
New settings after rebuild. Should this work?
2023-08-01 Neuaufbau.4ds
(255 Bytes) Downloaded 239 times
franz88
altitude limit it has two activations ON1 and ON2 based on the channel value assigned to the switch
in general channel what is written to you? (on1 or on2)
this settings you only see them with the radio turned on
let me understand but you use altitude limit and normal recovery?
why if active altitude limit and after you use normal rescue altitude limit takes the altitude than when you activated normal rescue.
This happened to me, but the rescue normal It has always worked fine for me.
only that between altitude limit and rescue normal the priority goes to rescue normal.
but he's always been good to me.
Only if you activate altitude limit and then you activated the normal rescue you should disable and re-enable altitude limit.
But is it possible to have all these functions active?
why in stabi mode you can only choose one option
PS
please write english.
Tanja
I'm sorry for confusing you. When the crash happened, I only used the altitude limit with Geo-Link in 5 Meter and normal rescue on a switch. When the altitude limit was engaged, the value was on (1).
Due to a mistake by myself, the Heli went downwards and the altitude limit was engaged. I did't pull the switch for rescue. Then the heli turned in inverted position. I tried to flip the Heli in upright position, but it wasn't possible. Then it crashed.
In the new settings, I try another way, without altitude limit. Because it's an Spirit GTR, I want to to use the automatic rescue with the barometer. On the rescue switch I only have the stabilisation, no more rescue with pitch. I hope this will work.
But I'm still very interested, why the crash happened...
franz88
try using one function at a time
I have checked your settings. I found that you are not using GeoLink Altitude Limit at all.
Instead you are using Rescue (Automatic) which is feature directly from GTR.
Are you aware of this? Altitude for the automatic rescue is programmed during flight, not from the software.
Tanja
thank you for checking the settings. I am aware of this. As long as I don't know what happened with the altitude limit when I crashed, I don't want to use it with the Geo-Link anymore. So I changed to the automatic rescue of the GTR.
Do you have an idea, why the heli turned and stayed in the inverted position while normal rescue with altitude limit? I want to make sure, that it's not an hardware issue, what can happen again. It doesn't feel good.
Kind regards
Tanja
