[SOLVED] Desktop software to small to read.
Uplate
Just got around to installing 3.61 on everything.
Desktop software is almost impossible to read due to tiny fonts. I even set up my scaling in Windows to max of 300% and other apps scaled, but not Spirit Software.
How to get the UI up to a readable size?
Thanks.
Mike
At the moment there is no way how to scale the fonts. The size is same at each computer. But if you are using extremely big resolutions it will appear to be small.
We will implement a proper solution within following days so it should work automatically soon.
Uplate
Thank you Tomas.
I have never seen this sort of scaling with any app.
Using windows surface at 2560 resolution works good for everything else.
Thanks for support!
The problem was resolved in the upcoming software version. It is under testing now and confirmed to work by Uplate.
Until now there was no support for high resolution screens on Windows so the app was scaled for all in the same way.
Now it is scaled up automatically.
