Hi All. I've been practising my 450l in stability normal but decided to change to scale. When I changed via the Bluetooth and a mobile the tail would not hold even when I pushed the gyro up to -90%. In normal I had it fine at -60% but I'm not sure what is happening in scale stability and why it won't hold solid. Can anyone assist maybe. Am I going up the wrong way should it be lower than -60.
Ta
Poor tail authority in stability scale
limabean1 wrote:Hi All. I've been practising my 450l in stability normal but decided to change to scale. When I changed via the Bluetooth and a mobile the tail would not hold even when I pushed the gyro up to -90%. In normal I had it fine at -60% but I'm not sure what is happening in scale stability and why it won't hold solid. Can anyone assist maybe. Am I going up the wrong way should it be lower than -60.
Ta
From my understanding, Stabi Scale is Rate mode Only, not heading hold
In Normal Stabilization, heading hold is or tries to maintain on all control surfaces.
Maybe this helps
Ta
for scale you should have i at around + 55-70% headhold. NOT negative side of the gyro
next i wonder is how did you set up you scale switch? did you go to CHANNELS and assignet a swith to STABI SCALE ?
then you go to the STABI Menu and put it in SELECT BY CHANNEL
if your heli was flying good before you put it scale then this should not make any difference for tail.. only cyclic/stability
unless you changed someting
