setting up 6 degree pitch on wizard
Pete678
I've gone through and programmed all my servos into the unit and set all for zero degrees at middle stick and I have all the correct movement and stabilisation correction set but, when I come to set the 6 degree of pitch it goes into a negative pitch, but if I move the blade to the side 90 degrees to the boom it is perfect at 6 degrees. I know in the wizard it says to do it parallel to the boom but like I say it comes at a negative pitch. The only thing I can think of is that I may have mixed up the pitch and aileron servo the wrong way maybe? Any help would be great.
.Thanks
ExCCHP
Are you measuring the blade Over the tail boom or the blade in the front?
I believe you are to use the blade over the front of the heli for All measuring.
Pete678
I've set a couple up before and I always do the measuring over the front and then make sure the rear is the same for mechanical purposes. I get negative pitch when it goes into the 6 degree set up mode. Haven't had it before do that's why I think I ,may need to go through the wizard again and switch ail and ele around and configure from there
senaka
I would redo the wizard by first setting it back to factory defaults, and taking it from there.
it might not indicate any issue. At the front you could get negative but at the rear it will be positive. It depends at which side you are measuring.
Pete678
so If I measure at the back and get 6 degrees then it will be fine as all the functions work as they should? Thanks
Yes, correct.
