Ethos 1.5.8 update / Spirit Ethos integration
Additional information what has changed in ETHOS 1.5.12, I hope this helps too...
Best regards
Matthias
parallel I had this problem reported additionally at GitHub (FrSky) and received this answer from the developer:
Tomas, please change the LUA-Script that it will work again with this version -
Thanks a lot in advance !
Best regards
Matthias
Frsky in Ethos is constantly changing something for LUA scripts. With this style it will never be done and everything will work correctly .. unfortunately
azaz44
Just for clarification, the red triangle was introduced recently and this way Ethos can tell you, that scrip made something wrong. But script is still running, like before. In my case integration script generates an error but still works. But I'm not on 3.7 in any heli yet.
azaz44
Or in other words, this script error was there in the past. It's just that in previous Ethos version you wouldn't see it. To see it you would need to connect a debugger. Since 1.5.10 Ethos shows errors in UI, but scripts work like before.
Hello azaz44,
yes you are right that the red triangle was introduced recently - but this means also, I read it in an other forum, that in this way it was avoided the transmitter going into EM mode -
Sorry mistake is a mistake and how can you be shure that the rest of the script works like it should ?
Hello Habásek,
Of course it is annoying when FrSky is constantly changing the scripts (commands), but what should the customer do then? Simply forget the integration? If I knew exactly what needed to be changed, I would do it myself, but unfortunately I am not familiar with LUA and not be able to implement any changes -
Are you from the developer-team ?
I think with this attitude you will lose some customers sooner or later, I don't know if that is what you really want to -
there will be update next week.
Hello Tomas,
thanks a lot for your support !
Kind regards
Matthias
Hello Tomas,
any news about the new Integration-script?
Thank you for the excellent work!
Best regards
Matthias
