[SOLVED] OMP M4 Max Telemetry
Crackers
I have been validating RPM Telemetry for 3 helicopters all using Spirit GTs and a TNC tachometer. The first 2 have Avian ESCs and the ESC telemetry was equal to the tach reading.
Today I tried to validate an OMP M4 Max. The RPM telemetry was 2,000 while the tach was 1,400. The sensing divider was set to 21 because the Sunnysky 8110 motor has 42 poles and the gear ratio was set to 1 because the M4 are direct drives.
Edit: Using an iX14 Tx and 4651T Rx along with Telem OMP cable pluged into the SAT1 port.
What did I get wrong or what did I forget? Thanks in advance for your help.
it is important to not set any Motor/Gear settings in the radio. It should stay at default values.
Crackers
Thanks for your help, Tomas. In Model Setup - Telemetry Utilities - Set Sensor Alarms - for both RPM and ESC, I set the Ratio to 1 and the Poles to Inhibit. The test results were spot on. The tach read 2000, 2200, and 2400 for normal, stunt 1 and stunt 2, respectively, and the telemetry on the iX14 agreed.
AndrewJohnHawes
So Crackers, I am having a similar discrepancy!
What were your Motor / Gear default settings, please? Is this supposed to stay at '1' for direct drive?
I have my M4 set to 21 and 1 and head-speed is close, but capacity and current draw are way off!
Regards,
Andy
AndrewJohnHawes wrote:So Crackers, I am having a similar discrepancy!
Regards,
Andy
RPM readout is not related to Capacity measurement. So this is very different problem.
His problem was double configured Gear Ratio which reusulted in too low RPM readout.
AndrewJohnHawes
I realize that rpm and gear settings are not related, just trying to fathom out why my capacity / current is so massively off!
Andy
