Assigning Spoken Anouncements to Flight Modes
AndrewJohnHawes
Why is this proving so difficult, really shouldn't be!
I am trying to set a "Normal", "Idle 1" and "Idle 2" mode with corresponding spoken outputs.
Just doesn't seem to want to play nicely with switch positions.
What am I doing wrong??
There shouldn't be any care as to what these modes are called - I am used to calling these Normal, Idle 1 and Idle 2.
I had problems with the spoken output when I first got the transmitter.
Am I misunderstanding something fundamental, or just being stupid about something. This is why there should be a written manual.
I have got most things sussed, but this should have been so much easier. I know printed manuals are expensive.
Am I misunderstanding priority settings or something as such?
Regards,
Andy
AndrewJohnHawes
I want to say that I have been flying RC helicopters for more than 43 years.
I didn't think I was stupid with some of this stuff?
I am starting to feel stupid.
Regards,
Andy
Mrclox
Model menu
Flight mode
Add
Highlite
Set
Click coloured switch button
Toggle desired switch on radio
Confirm
3 slide buttons... Swipe right on switch position desired
Swipe window left
Switch on voice output if not already
Click change
Type in box name of flight mode
Click return on keyboard
Repeat above for each mode you want
Ps it may not let you choose a new name for flight mode if connected to receiver. Power off model
I have no idea how this could be difficult, because procedure takes just 2 steps. You can do them at any moment.
To enable Flight Mode Voice Output:you need to go to Model - Flight Mode - there enable Voice Output for each Flight mode where you want Voice Output.
For each flight mode set desired Voice Output text. Nothing else is really needed, these steps can be reproduced easily with new model.
I have no idea at which step you have problem, it could take all less than one minute. If something is not clear, please let me know.
AndrewJohnHawes
Thank you each!
I have no idea either why it should be difficult, but it IS proving to be.
Like I had previous problems with the speech output being inconsistent when I first got the radio some months ago, it just was.
The upgrade suggested, did work for a while, but is again now not remembering speech output settings, even after checking output.
Certain chosen speech phrases are being altered, etc.
I have tried disconnected from the model, many times! The setting process gives the impression that this should work very simply, but it is not doing what it is supposed to do.
I have recently upgraded the radio firmware and that of the W1, however.
I am going to try one last time this evening.
Regards,
Andy
AndrewJohnHawes
It appears that certain phrases might be protected, like 'Throttle Hold', or associated with the Throttle Hold?
Andy
AndrewJohnHawes
The fundamental issue is that the older generation, and I count myself within this group, are used to referencing a physical manual.
I have referred to a few online youtube videos and have resolved various issues. However, where I know what I need to achieve having used Sanyo, Futaba, JR, Spektrum, VBar, Jeti and now Spirit Wave for more than 45 years, many people of my generation coming to RC systems later do not have this perspective!
I know that traditionally printed manuals are expensive and inflexible in accommodating new versions of software, hence the online versions, but the online versions, especially ones that are still in a state of flux, are less than ideal.
Spirit has tried loyally to produce, what is proving to be a superb radio, without too much delay - I understand the marketing pressures, I promise, but a hard copy manual would have appeased many people.
Simplistic issues in radio set-up would have been avoided, the new operating system would have been a little less opaque!
Maybe I am just getting older and less flexible, Yes I definitely am that, but this was a very minor OWN GOAL for Spirit.
In conclusion, I am really liking the Spirit Wave radio, and am considering buying a second Spirit Wave radio to teach RC fixed-wing and helicopter (I currently use Jeti for this purpose), I really hope that attention can also be focused on clarity with this new operating system - I know that the substance is there, just am finding difficulty in adjusting in some corners!
Andy
thank you for explaining. We are fully in agreement and know urgent need of the manual.
We are working as fast as possible to finish all the tasks. Fortunately recently things are moving very well and we expect to dedicate full time at this from next week.
AndrewJohnHawes
Thank you for your reply Tomas!
I look forward to this in the near future, as I know many other people will too.
Andy
