I wanted to use older GTR units on a fixed wing, but see no manual support ?
I have software loaded with a small 2 x aileron model set, but little manual detail ?
Andy
Spirit GTR with Aero software ?
AndrewJohnHawes
PS I was using this with a Jeti Radio, should I try to use this with the Wave, or do I just need to use a wave receiver?
I wanted to use this as a trainer, hence the GTR / Jeti, as I only have one Wave radio so far !
You can find manual here:
http://aero-man.spirit-system.com/index ... =Main_Page
AndrewJohnHawes
Thank you, I have seen this before, but the manual here does not show GTR Aero connections which was my initial question.
Should the ESC be connected via AUX1, or via one of the other channels?
I have a simple aircraft with 2 x aileron servos (do I need to just go "Y" lead?) and 1 x elevator and rudder. Which output channels should these be connected to?
The manual does not cover servo connections. I guess I will just have to play around to work this out.
Andy
Andy
Throttle should be connected at the THR port always with GTR, RS and W1 units.
Ailerons are connected at CH1 and CH3 ports - see the Setup Wizard or Aero manual here:
https://aero-man.spirit-system.com/inde ... tle=Wiring
New big Spirit Aero update is on the way! We plan to release it next week together with full Wave support.
AndrewJohnHawes
Thank you for your help, as always!
However, the link you provide shows, generally, connections for Micro Spirit, Spirit and Spirit Pro, but not GT or GTR.
It indicates, with these other units, that ailerons should be connected to Ch1 and Ch3, but is unclear about the Throttle / ESC connection as the GT / GTR units are neither mentioned nor displayed in this section.
Sorry, not trying to be pedantic, but this was my original issue, the lack of inclusion of GT and GTR as examples.
All clear now and, hopefully, with the new version update will make all this a lot clearer.
Andy
Andy
