swashplate not moving correctly in stabilisation mode
Dcwater
Hi ALL,
I am a newbie in setting the Spirit or any FBL unit.
I have trouble setting the Spirit GT in the Stabilization (normal) mode.
I cannot get the swashplate move in opposite direction to counter(compensate or stabilize) the heli movement.
When I tilted the heli forward, the swashplate also move forward.
But when i move the stick right, left or forward and pitch, all the swashplate movements are correct.
I am using a Spektrum ix14 radio.
I know this might be something very obvious which I am missing.
Thank you in advance for your help.
Dave
Mona
Check that channels move in the correct direction in diagnostics tab, and unit mounting orientation and swash plate type are configured correctly. Only then use servo reverse to get it to move correctly with sticks.
Do not just reverse channels in the transmitter after setting it up using diagnostic tab to get the swash to move in the right direction, always follow the procedure.
