SUNNYSKY X300A HV SBEC + Backup Cap to Spirit2
nmsantarelli
Good morning to all of the forum,
in the Spirit2 manual it is specified to use the two BEC outputs for models like mine which is a 700.
Checking the connectors coming out of the "SUNNYSKY X300A HV SBEC" there are two cables such as:
"Throttle/+/ -"
"RPM/+/-"
At the moment I have only connected "Throttle/+/ -".
Question:
Can the second connector "RPM/+/-" be inserted in AUX2 or do I have to isolate the yellow RPM cable and connect only "+/-" in AUX2?
I should also connect a "Backup Capacitor", in which port can I connect it?
To summarize the current connections are:
AIL pin -> SRXL2 adapter -> SPM4651T
RUD +/- -> SRXL2 adapter -> SPM4651T
AUX1 T/+/- -> Throttle from ESC
AUX2 ?/+/- -> Additional power from ESC
Ch1,2,3,4 -> Servos
Sys port -> only for interface
Thank you in advance for any help.
Mona
Manual says RPM signal on Spirit 2 goes on "PIT pin - pin in the middle of ELE/PIT/AIL port".
Connecting RPM signal to AUX2 won't do anything, won't hurt anything either. Just never connect power to ELE/PIT/AIL or SYS ports (the outer ones). Depending on receiver (if it runs off BEC power and has extra ports with a common power rail) capacitor pack can also be connected to a free receiver channel (don't think yours qualifies). Alternatively y-cable on BEC power should work.
nmsantarelli
Mona wrote:Manual says RPM signal on Spirit 2 goes on "PIT pin - pin in the middle of ELE/PIT/AIL port".
ok thanks for the thought
