I like the current 2-way long momentary switch, but I would like it even better if I had the option to reverse it. I tried reinstalling the momentary switch rotated 180°, but the switch connector interferes with the back plate of the case and does not allow for 180° rotation of the switch. I can replace this long 2-way momentary switch with a standard "non-momentary" 2-way switch, but what I would really like is a "Reverse" 2-way long momentary switch...or a push button.
Does Spirit have any plans to release a "Reverse" 2-way long momentary switch?
Reverse 2-way long momentary switch??
We already made this modification for one customer. We can ship it for you too.
Will be official possibly next month.
curmudgeon
I would love to order 2 of those reverse long 2-way momentary switches along with a few other items. How can I go about ordering these switches and the other items today?
Thank you!!
Thank you!!
You can place order for normal momentary switch with order message - reversed momentary switch. We will ship you this version.
curmudgeon
Very well. I will place the order for the 2 momentary switches with a message stating I want them in reverse.
Will it be possible to make regular 2-way switches in "short" rather than "long" version as well?
curmudgeon
I received the long 2-way reversed momentary switch today. I installed in the WAVE radio for use as "Rescue" in the LD position. Since I a "pincher" and I rest my middle fingers between the top two switches, I can now activate "Rescue" super fast in a moment of panic with this reverse momentary switch. Thank you Tomas for making this long 2-way reversed momentary switch available.
The last switch type I need to make this radio "my own" is a short 2-way switch. I am using a long 2-way switch now where I would prefer using a short 2-way switch. I am considering cutting the long 2-way switch short and cover the sharp cut edges with a rubber switch cover, but my preference is to use a factory made short 2-way switch.
Does Spirit have plans to make short 2-way switches available?
In next 2 weeks it will be available. You are welcome .
curmudgeon
I look forward to it.ZeXx86 wrote:In next 2 weeks it will be available. You are welcome .
Thank you!!
