HARD DECK AND RETURN TO HOME PROBLEM
raceboy1
fIRST, i HAVE FIVE hELI'S SET UP WITH THE SPIRIT GT AND THE GEOLINK
And the below is the only one that I'm having this problem with .
On my 580 Electric the RTH and Hard Deck will not activate when I first initiate
I have to let the motor spool up and then hit Throttle Cut.
After doing the above I then have control for both the RTH and Hard Deck
Using an IX14 Spektrum Transmitter
Any Ideas why this is happening ????
I recommend to try Cleaning GeoLink Logs. Or you could try to disable GeoLink logging temporarily.
Can you attach your settings file please? I will check it. I never heard about this kind of issue, but I am sure it can be resolved.
raceboy1
OK, I tried clearing the logs, but that made no differance
I attached the Backup file for this Helicopter, hopefully you can use that
Thanks,
John
580 ELECTRIC SPIRIT.4ds
(255 Bytes) Downloaded 174 times
