Pitch range has a default of 64 displayed in the documentation.
If I set the range to 64 and have full pitch on the stick the helicopter seems to have very little pitch.
I've set it to 160 and it seems better.
Just wondering how that dialogue works as there seems a vast range to choose from?
What is a normal number?
Too windy at the moment to do a proper test.
Note:- this is for an OMPhobby M4 Max
limit tab / pitch section.
AndrewJohnHawes
I have just looked at my pitch range setting for the OMPHobby M4 (Not Max).
I have 13 degrees set using a figure of 135 in the Spirit Wave.
I hope this is useful relatively?
Andy
Andy
Don't over think it or put too much faith in that number under the slider.
Also just because one model has a setting of 135 in Spirit to get 13°, that does not mean it will be the same on another model.
As said, set the slider to get your desired pitch and move on.
Thanks guys, that is reassuring.ExCCHP wrote:Don't over think it or put too much faith in that number under the slider.
Pitch Degree value is based on Geometry parameter. So same number will be really different between models
