Damping rubbers for mounting Spirit unit?
Konrad
When building the Il Goblin 700, you have the option of mounting the Spirit with or without damping rubbers. Some say that the steering response is more direct without the rubbers. Others say that it dampens vibrations better. What would you recommend? And why?
Thanks,
Konrad
Nazar
On my Sab Maverick i removed the rubber dampers and heli flies great! No downside to it.
Mona
On the raw 580 you also have this option and I went for the hard mount. Figured on an electric model in good condition the tape should be enough. The Spirit GT certainly doesn't have any problems with it, software filtering is plenty.
Oddly the ilGoblin raw 700 also has both options, but the pro only comes with the rubber dampers to my knowledge (manual doesn't mention the other option either) even though it uses the same mounting plate.
