Jeti Integration 4.03?
Michldigital
What about Jeti integration for version 4.03? Will there be a version for this? If so, is there a release date yet?
Greetings
Maik
It will be released same as for each previous version. No release date yet, but it might be next week.
gerry
When is the Yeti integration (bin.file) 4.0.3 coming
Greetings Gernot
On monday we should receive BIN file from JETI model.
Michldigital
Any news? Do you received the bin file?
Michldigital
What about Jeti integration for version 4.03 or 4.04? Will there be a version for this? If so, is there a release date yet? Any News ? Bin file from Jeti received? An answer would be nice
gerry
It has already been promised for some time. For me, a new version 4.03 or 4.04 is completely worthless without a suitable Jeti Bin file.
Greetings Gernot
AndrewJohnHawes
Hi All!
I understand that you are frustrated that the latest upgrades are not supported by Jeti Integration files immediately!
It appears that the latest upgrade is mostly accommodating hardware platforms, and in such cases will not need to be constantly amended and tuned, once set.
So constant field/radio tuning should not be an insurmountable issue. Once set correctly on PC or other, should not require continuing changes. Hence, the BIN file lag, although a little frustrating for some, is not the biggest problem in the world.
Really guys! These are not 1st world problems, and in reality are only minor teething problems!
I am not saying that these should not be forthcoming, but I think that Spirit should be cut a little slack! I am happy that they continue to develop and provide upgrades, even if it takes a little while for integration support to follow!
Many platforms are not giving regular updates and I know the amount of support that ZeXx86 provides, listening to real problems and attempting to solve them!
At the possible expense of drawing some flak, we should all show a little patience.
I currently have a lot of innovations still to implement.
P.S. I do use both Jeti and Spirit.
10x
Well said Andrew...Totally agree....
AndrewJohnHawes wrote: Thu 21. May 2026 8:02:21 Hi All!
You can update BIN file now. Available for download. Thank you for your patience.
