6degree tuning
So when I tick the 6 degree box I immediately see the left pitch servo drop and only this one. Is this correct? I have gone thru all the other stages and I thought this was the last thing to accomplish however I could only get to 8 percent even though I,m not sure if this function is supposed to work this way. I might have been able to get to 6 but the numbers would not let me get to what the highest number allowed. Please advise, thanks
Does anyone know the size of the wire on the ball link and the thread size? Its a Trex 600. After thinking this over I believe that is the only way to fix this by raising the swash plate a small amount and I'm not sure if I can unwind the thread enough and still be safe. If I can find the size Ill buy some stainless wire and run it thru a die. If I'm way off I hope someone will steer me right.
I;m having a time with this 6 degree geometry. I redid the whole head and It looks perfect to me however at the lowest slide adjustment I'm still at 7 degrees. What in the world do I need to do my brain is hurting. I'm assuming this is done at 0 degree stick centered? I would appreciate some guidance, thanks
