Spirit 3 throttle servo
tragi700
How do I get the throttle servo working on a spirit 3 with my Futaba 32mz, I have plugged it into
Aux1 but the servo will not work.
First you need to assign Throttle function to a Channel - usually Channel 1 at the General / Channels window.
Then it should work immediately according channel movement.
tragi700
I have set throttle to channel one in spirit software, My transmitter has throttle set
to channel three as is standard with futaba. I have tried changing the futaba to channel
one with no luck and have tried changing the spirit to channel three with no luck.
Please perform further firmware flashing to the latest 4.0.4-r2. Then it should work well.
tragi700
Thank you, that worked.
