Wave startup error - preflight check
Christian
I have a serious problem. My Ware radio does not start properly anymore. :o
When trying to start, Wave makes preflight check and says Motor=-100% is not equal to -95%.
Is there any way to skip the preflight check during startup?? I am lost.
This check was working before!! Software is 1.0.33. Today I switched off the Motor -100% check by any reason and switched it back on later, because I thought might useful to keep.
Now, it block's my startup :evil: what can I do to get it run??
Christian (Germany)
Christian
Ok, solved. I found a way to interrupt the preflight check. Long press and hold on the screen.
I also found the root cause of my problem: had a well working preflight check for throttle<-95%. When I switch out and switch on again this check, the condition is changing from throttle<-95% to throttle=-95% (!). Next time you are starting your Wave it says throttle is not equal to -95%, this is clear because throttle cut put it down to -100%.
This is stupid
Christian (Germany)
