differences in setup on helis with high swash to grip ratio
trillian
So, we have some helis touting a '1 to 1' geometry between the swash and the main grip pitch. And then, as in the case of some F3C machines, there is quite a bit of reduction in motion between the swash and the grips.
Are there any settings that should be done differently in a heli with a high cyclic ratio, vs one that is closer to 1 to 1? Or is it all down to the 6 degree setting in the Advanced tab?
Kasama Faifa and Dune, Shape S8, TDR, TDR2, TDSF, Core 700, HD750, Steam 700, RVE Dubhe, Triabolo 700, Protos 700, SAB Black Thunder 700, Goblin 770, Synergy E7
