Bugs in Jeti Integration
Konrad
I’m using Spirit Setting Software 4.0.6 and what this software identifies as the latest Jeti integration file. I tested this with a Spirit GTR running the latest 4.0.5 firmware.
Using Jeti alone, it wasn’t possible to set the bank switch to channel 7. After turning the power off and back on, the bank channel was always marked as “unassigned.” The assignment could only be made via Spirit Setting on the PC. So far, so good.
The serious problem now is:
I set the Piruette Consistency to a different value for each bank. When I saved the settings, the bank switch was set to Bank 2. Banks 0 and 1 were saved correctly. Bank 2 was not.
This is a typical situation: You select a bank, change a bank-specific parameter, and save. In the subsequent flight, the new value isn’t applied. However, if you switch to Bank 0 before saving, the value set in the other bank is saved correctly. I’d say this is a pitfall.
Konrad
