Tail kick not wag
Neil-H
Hi I have the spirit3 gyro fitted to trex 470 and trex 300x , I have this slow tail kick it's not a wag it does it sometimes after a cyclic input also in a hover it will kick every now and then the tails are smooth on both helicopters so at a loss of what to adjust
My set up is futaba transmitter and Sbus receiver ,HV align servos , XDfly ESCs on both helicopters running governor mode , both helicopters are belt tail , tail and main blades balanced and are tracking spot on , both helicopters tails are butter smooth
On.my goblin 630 I have the spirit pro and the tail is rock solid on default settings
can you share settings files from these units?
What tail servos are used there?
Neil-H
Hi sorry do you mean the saved file that spirit unit saves to my pc , I can get these at the weekend for you , all servos are the align servos
470 and the 300 has the DS455 servos on the tail
Neil-H
Are these what you need
align 470.4ds
(255 Bytes) Downloaded 11 times
trex 300x.4ds
(255 Bytes) Downloaded 15 times
