geo link problems
neils
geo link return to home function in mode 4 power up on the spot does not work, All my settings are correct in the software and my spirit wave transmitter everything working when i throw the designated switch.
At the flying field with 16 sats showing it does not register the take off position. i am on firmware 4.05 and my wave transmitter , geo link and spirit receiver are updated.
Can you confirm if there is a problem within the spirit software ? The problem is the same on all my 5 helicopters. Position hold and altitude hold work perfectly . I have used your AI help on the system which confirms my settings are correct. Other pilots at my club are having the same problem.
delta peak
Before take off is Geolink led steady blue?
neils
Hi there, yes steady blue with 16 sats confirmation on my spirit wave transmitter telemetrey
delta peak
What do you mean with "does not work"? Can you explain?
neils
Hello
Geolink return to home, mode 4 , power up on the spot is not registering the take off position, according to the manual the take off position should register as the heli powers up and lifts off. this does not work as when RTH is activated heli flies in wrong direction. this is happening on all my Helis. On the bench and in the software it all works fine, but not at the flying site.
All my geo links were working great until the update 4.0 , my freind has 1 heli that is working correctly but that heli is on 3.7, we are convinced there is a problem in the new firmware.
