Tomas,
One quark I have noticed with the new software is when I assign bank switching to channel 7 using futaba sbus, after it asks me to save, I click yes, and all the servo's go crazy spazming back and fourth until i turn it off and back on again. Once I reset it, all is good and settings were saved, however, I am not sure why it does this when saving changed settings to the unit sometimes.
Servo's go crazy when saving unit
Thank you very much for the report.
This is not good, do you have throttle channel assigned?
On my Gaui X3 I do. Throttle channel is assigned to Channel 1.
On my G570 I do not as I use the channel where it would go to power it and throttle is directly into the Rx.
Both have had this happen. Fortunately it causes no damage and the unit saves properly and all is normal after I reboot the spirit.
This happens anytime I save or pull the logs from the unit on the X3. The Scary part is since the throttle is controlled through the FBL it starts to spin the blades up. Luckily it doesn't stay on and only moves them a little bit, but, that is definitely a concern.
Sorry to hear about your issue, unfortunately I can't reproduce it,
but I will investigate where could be a problem.
Do you have assigned channel for Throttle in both units?
What RX/TX do you use?
Could you send me/attach your settings, please?
Could you try this firmware, please?
http://spirit-system.com/dl/fw/test/spi ... 1-test.bin
Also I recommend to download version 1.0.25.1 before the update:
http://spirit-system.com/dl/settings/sp ... -win32.exe
Thank you very much
Thank you very much
Here is my current file for the Gaui X3 with X4r frsky rx, Tarot S.bus adatper, Hobbywing 50 amp V3, and Taranis Plus Tx.
I am using a Lenovo Laptop running window's 8.1
- Attachments
- X3 first setup.4ds
- (255 Bytes) Downloaded 232 times
