Great, I guess default values from Tarantis are just not very good for S-Bus protocol. Btw throttle channel should be cutted of in case of failsafe - that is default behavior of nearly all ESCs, receivers and transmitters. If not, your model can fly away.Jman841 wrote: However, it also activates rescue. Not sure if that is a good or a bad thing. Could be nice if I loose signal but it will also cut throttle so may cause more damage. I think I just have to adjust channel 5 to be a positive value when failsafes go on.
Simply this issue was caused by incapability of S-Bus protocol - it is not prepared well for values like 0, 0, 0, 0, 0, 0, because protocol is not able to recognize its start and end of the frame.
For example, my Futaba does not allow even to set failsafe for all channels. I think that it is because protocol limitation.
