how can I determine which firmware version isn on the spirit?
I thought, i have flashed it to 1.0.25.1, but displayed is only the "old" version 1.0.25.
Btw. is there a difference in the software between 1.025.1.and 1.0.25 ?
Friedl
Firmware version ?
you can determine it by filename you have downloaded and flashed.
Software and firmware always contains version.
in the following version it should be improved, so full version will be displayed.
At the moment there is protocol limitation.
We will use all these subversions, so all current ones are required.
