Stabilization
ramaa0211
hi,
is the aileron limited in the stabilization
djhandz
Hi both ail and ele are limited in Stabalization mode
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
ramaa0211
ramaa0211
can i change this and why is the nick not limited??
there is nearly no roll in the stabi mode
thanks
djhandz
Stick priority in the stab tab. I have mine set to 16 this gives plenty of control while in Stabalization mode
linux-user
ramaa0211 wrote:Hi,
thanks
Hi, ramaa0211
you are from Germany?
Just in case here my "not too scientific" translation:
German <-----> english
Nick, Höhe <-----> elevator
Roll, Quer <------> aileron
Gier, Seite <------> rudder
Pitch <-----> pitch (special for helicopter)
Than your question would mean:
"...why is the elevator not limited??"
Do I understand you right?
you feel that:
- aileron is very limited?
- elevator is not so limited?
ramaa0211
Hi linux-user
you are right,i´m sorry :mrgreen: :mrgreen:
yes, the aileron is limited and the elev not
thanks
linux-user
ramaa0211 wrote: the aileron is limited and the elev not
I have no experience with stabilization-mode, so it is some guessing:
Maybe your transmitter is limiting in some way.
e.g. different D/R settings for ELE and AIL
- in the Diagnostic tab of Spirit-software, are there aileron and elevator moving both from -100% to +100% when in stabi-mode?
I am not aware of any setting in Spirit, that limits aileron more than elevator.
Manfred
ramaa0211
there´s no limit in the transmitter.
all signals moving from -110 to +100
Grüße
Ralf
With stabilisation do you mean special Stabilisation mode that is activated when Gyro Gain is negative?
Or do you mean conventional flight mode?
You have to set Channel ranges to +/-100% in the diagnostics tab with Travel Adjust in your transmitter else rotations will be unequal to some directions. For more instructions check section 5.5.3. in the manual (Page 19).
If you are moving with sticks and your helicopter is on the ground, do you see equal movement of the swashplate?
