Wishlist (Bluetooth app)
btheli
Bluetooth app wishlist
1. Make it easier to see and change the parameter values in bank 0, 1, and 2. What would be nice is to add a tab that displayed a table of values you could see and change, all on one screen:
Parameter Bank0 Bank1 Bank2
Flight style 4 4 4
Cyclic gain 50 47 44
Cyclic agility 8 8 8
etc
etc
etc
2. Add an "exit" button in the app that disconnects and exits the app. Exiting the app now using the back arrow does not disconnect (blue light is still solid). I have to manually kill the app to disconnect.
error414
btheli wrote:Bluetooth app wishlist
Flight style 4 4 4
etc
etc
etc
Now it works like this, just tabs are not horizontally but vertically and are opened by sliding.
btheli wrote:2. Add an "exit" button in the app that disconnects and exits the app. Exiting the app now using the back arrow does not disconnect (blue light is still solid). I have to manually kill the app to disconnect.
this disconnecting is not recommended because it does not switch on the transmitter-controlled banks. it is sufficient to reopen the application and disconnect BT.
developed version has functions caution when unsaved changes
Logo 600 3D -> Spirit FBL
Spirit settings Developer
btheli
Warning when changes have not been saved and bank comparison are great. When will they be in the Android application? The version on my phone is 1.0.25-2 and it does not have the bank comparison function.
error414
im sorry :(, this is develop version 1.0.26, will be release same time as firmware.
nougiw
Is there any chance that the android app supports connection through usb too besides bluetooth? I recently bought a relatively small tablet with a screen which is way bigger than my phone's but it has no bluetooth (so the app cannot be installed "your device does not support it") but it has usb! It would be way more convenient than carrying my laptop to the field...
error414
Support USB (OTG cable) was never intended, but I'll check if it's at all possible
nougiw
error414 wrote:Support USB (OTG cable) was never intended, but I'll check if it's at all possible
It's been quite some time now. Any news?
igloo
+1 (thanks in advance for the reply)
error414
Hi, it is possible connect to spirit over FTDI -> OTG but i have to rewrite app core in android apps :(. it will not be quickly :((
igloo
Tks for this answer and your work.
