3blade head and spirit possible??
Great, so in this case, you should increase Governor Response first.
If you feel that it does not make any difference, try to increase Max. value in the Throttle Range, for example by 5-10 points.
Joeri_Plees
ZeXx86 wrote:Great, so in this case, you should increase Governor Response first.
I have the governor response on max and the difference between the max and default isn't noticeable.
And have you a photo of what you mean with throttle range please I doesn't have the software right now maybe I now if I see what you mean what my value is.
Verstuurd vanaf mijn SM-N910F met Tapatalk
In this case, the problem is most probably in the Throttle Range - Max. parameter.
You can try to increase it from 100 to for example 110. Then you should feel difference.
Joeri_Plees
Oké I understand I gonna try that fast as possible thanks man! Hopefully it works I love the unit on its own and using the esc governor but because the hobbywing governor is s**t I must use the spirit for it so hopefully it's gonna works otherwise I must by a new esc
Joeri_Plees
Increase is from 100 to 110 and negative also from -100 to -110 or only the positive side?
No, only 100 to 110. If you will not notice difference, than you can try 120.
Joeri_Plees
Oké thanks
Joeri_Plees
It's help a little with the 110 setting but not very much... Try 120 now? Or what
Yes, you can increase it to 120 until you will hear that there will be excess overspeeding - after some hard manouver RPM will drop slowly from the highest to the requested.
Joeri_Plees
Nope it doesn't work I gonna buy a good esc with a good governor that's the only solution I think
