3blade head and spirit possible??
Joeri_Plees
Hello
Is it possible to use a 3 blade head with the spirit because I have some problems with my Oxy 3 qube...
Best regards Joeri
Verstuurd vanaf mijn SM-N910F met Tapatalk
yes, Spirit is working without any problem with any head.
You have to only set the unit with respect to the mechanics.
For example some rotor heads need virtual cyclic rotation to work.
Some rotor heads can work without any additional configuration.
Very important are blades. For example by using a plastic rotor blades you can get very, very bad results with FBL.
Joeri_Plees
I'm using the 3 blade head form Oxy of course on one of my Oxy's and I'm using Zeal carbon blades so that will not be a problem
Could you describe your problem so I can help you?
Joeri_Plees
The governor doesn't react like it must do, it's like he has no power enough.. I have already tried to lower the pitch and try new lipo's.
I use the hobbywing rpm sensor and the sensor need 3.5V-8.4V and I use the side of the spirit for it that's 3.3v so maybe that's the problem but I don't see anything changing if I put it right in de spirit with a Y cable
It's like he is missing some power... But that is also not the problem I asked that in the Oxy topic on helifreak
Can you take a photo of the RPM sensor connection? Especially from the Spektrum connector.
Important is that polarity is correct.
But this isn't a problem with 3-blade rotor head, so I should rename the thread.
Joeri_Plees
Not sure if that is not the problem
Joeri_Plees
Your connection looks correctly.
Can you see anything in the Current RPM and Requested RPM in the software?
Joeri_Plees
ZeXx86 wrote:Your connection looks correctly.
those are booth the same and correct...
