Page 2 of 2
Re: Tail blade linkages, trailing or leading
Posted: Tue 16. Feb 2016 9:30:28
I also recommend to not use Revomix. It should be used only for Scale helicopters or with servos that are too slow.
Correct piro consistency, rudder delay and gyro gain should be configured first.
What is your helicopter and what rudder servo is installed there?
Posted: Tue 16. Feb 2016 9:42:47
by Campbell
ZeXx86 wrote:I also recommend to not use Revomix. It should be used only for Scale helicopters or with servos that are too slow.
Its a KDS Agile 5.5 with a kds N650 tail servo.
Posted: Tue 16. Feb 2016 9:47:10
You can set 0-5 Rudder Delay and Piro Consistency should be in range of 160-170.
Then increase Tail Gain so it will hold.
Posted: Tue 16. Feb 2016 9:49:38
by Campbell
Posted: Tue 16. Feb 2016 18:51:51
by jgiannakas
ZeXx86 wrote:You can set 0-5 Rudder Delay and Piro Consistency should be in range of 160-170.
What will the heli do if you have too high a delay on a very quick servo and vice versa - too low a delay on a slow servo? Would be good to understand so to take note when tuning?
