wow 2.0
john1127
I pulled all servo wire off and rechecked all. All was right, Ive flown it6 months with pro. Tried up date again and all sefaces are going wrong, not only in direction but also wrong functions. Whats up.
ail-ch1 rt servo
ele-ch2
pic-ch3 left servo
rud-ch4
thr-aux1
+ - rudder.
dual sat.
dx8.
trex 600 N DFC
It may be necessary to redo completely settings in the transmitter including reverses and travel ranges as described in the announcement and during update process in the popup window.
I recommend using default profile in the transmitter, it may be enough to make everything OK.
john1127
when update from 1.3 to 2.0 do you use software from 1.2 and fireware from2.0 or does it matter.thks
Coco66
You should update to 1.3.2 using 1.3.2 software then upgrade to 2.0.0 using 2.0.0 software.
