This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
Then I went to my nitro and all went bad. Spent 2 hrs after update and eventully had to go back to 1.3. All controls were wrong, and I mean bad, tried swapping 1&3 no good. trex 600 dfc N.
wow 2.0
Did you reset the reverses in the TX?
What do you mean with "all controls were wrong"? Diagnostic screen? Or not responding correctly to inputs?
I suggest to redo the setup from a clean situation, no reverses, correct CH2 and CH3, and go from there.
Did you try saving the config, and rebooting the unit?john1127 wrote:all inputs on diagnose sere right from trans. Justall on heli were wrong. throttle made rudder move, ect
Channels assignments got lost, this could be the only explanation....
jgiannakas
I'd strongly recommend that you redo the setup. Reset the unit to defaults upgrade and start over with the wizard. Also reset all channel reversals on the transmitter.john1127 wrote:This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
I see we are on the same page.jgiannakas wrote:I'd strongly recommend that you redo the setup. Reset the unit to defaults upgrade and start over with the wizard. Also reset all channel reversals on the transmitter.john1127 wrote:This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
Unfortunately, if I read correctly his last post, the OP wants to hear from the Spirit guys only.
jgiannakas
+1. It just seems like an incorrect channel assignment that can be resolved in under 2 mins but to be on the safe side a clean start would be probably the bestCoco66 wrote:I see we are on the same page.jgiannakas wrote:I'd strongly recommend that you redo the setup. Reset the unit to defaults upgrade and start over with the wizard. Also reset all channel reversals on the transmitter.john1127 wrote:This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
