[SOLVED] Wifi connection Spirit Unit not found
Heli1458
I think it is a Hardware Problem.
Can i send you the Spirit Pro unit and the WiFi Modul to
Check it and if possible repair?
Yes, this is not a problem.
We can fix any problem in 1 day. We will check everything and tell you where was the problem. I believe that it will be nothing too bad.
Please send everything that you wish to the address that is on the white Spirit box.
Heli1458
I have no white spirit box .
To which address should I send the device
Coco66
Heli1458 wrote: Hello Coco66
I have connect with Spirit Wifi-Link 1B0.
There is no bluetooth modul
That's what I meant, I was wondering if the App was thinking you have a BT adapter and trying to connect like that.
If Bluetooth is ON in the phone, the Spirit App lists the possible BT connections and not the WIFI text I wrote you above (WIFI [192.168.4.1]).
Please check PM, I have sent the address.
Heli1458
I have a usb interface ordered from them . I can now my Spirit per the firmware 2.1.0 update and adjust my heli Per usb .
Thanks for the fast delivery and perfect service . :D :D :D
I still have a problem with the Wifi Link , but I try themselves to solve it . If I need help I sign up again
Gruss Heli1458
