Totally confused on Stability (Acro)
Thank you for the details!
I am glad it is working now.
The easiest solution is to unassign Gyro Gain and use just Bank Switching.
Then to set negative gyro gains in the software directly.
Then you can just change Banks with one switch (that will trigger the Rescue). Otherwise Stabilisation will be active.
This solution can work with nearly any radio but has limitation for just one Gyro Gain.
