Frsky X6R receiver SBUS connection to spirit (red)
t-guenni
I can set SBUS and save if I connect ESC directly, but if I go back to SBUS cable no connection is possible. Setup software crashed sometimes. I'm on WIN 10 64bit, I will try 32bit tomorrow.
THX for today
That is really strange.
Isnt the SBUS adapter cable hot?
It should work on all computers with no problems.
I have checked your photo again and I am not sure, but it look like the SBUS adapter cable is in the AUX port in the unit. Am I correct?
t-guenni
HI ZeXx86,
today I tried a other PC, same issue. No connection via SBUS cable possible. SBUS cable is in RUD connected. RUD is working with PWM, so port should be ok. I guess the SBUS cable is broken. Could you pls send me a new one?
I have installed via PWM now , this is working on all chanels.
BTW: the receivers fimware is on LBT EU version!
BR
Guenter
Dear Guenter,
thank you for the message.
OK, we will send you new cable tommorow. But since we are testing each cable before shipping, it is strange that now it does not work.
But I hope that it will solve the problem. Yes, you are right that the port will be good.
If this will help, we will need to send the old cable for inspection because this should really not happen.
can I ask you if you have ordered the SBUS Adapter cable?
This mean not just FrSky integration cable.
Both cables are different inside and for a different purpose.
t-guenni
the order number was 18003478 .
I didn't notice that there are 2 different cable types.
I see, I have orderd wrong cable :shock: , my fault....
BR
Guenter
Ah, so problem is solved.
The cable is not wrong, because you can use it for the FrSky integration:
t-guenni
yes, I will do integration later on. Is there somewhere a video about frsky integration?
I will order SBUS cable today and we see what happens...
Thanks for help!
BR
Guenter
OK, thank you too!
