Page 2 of 2
Re: uSpirit + Geolink problem
Posted: Sun 21. Oct 2018 21:16:17
uSpirit is using internal oscillator always, so you will see the event always. But that is all correct with uSpirit. But it is not correct to see with Spirit and Spirit Pro units.
I will check the logs and configuration. Unfortunately it is very hard to find the problem since it can't be replicated with any of our helicopters where it is working perfectly always and with any unit. All the features were tested for months with hundreds of pilots around the world. But we are working hard to find the problem in your case.
Posted: Mon 22. Oct 2018 14:52:30
by Xform
That is very interesting it worked perfectly for you in Czech Republic. Does this have to do with the United States and its magnetic field differences? Thanks for helping us. I am sure you will get this fixed. Altitude limit (hard deck) is mostly working, but it still has the problem misjudging the altitude sometimes activating too high, then too low. However, this is a big step in the right direction for GPS. There will be a time when we do have an uncrashable heli.
Posted: Mon 22. Oct 2018 20:43:12
by urgno
Xform wrote:That is very interesting it worked perfectly for you in Czech Republic. Does this have to do with the United States and its magnetic field differences?
thats why you have to re-calibrate the unit before using it
Posted: Mon 22. Oct 2018 22:33:37
by Pking
urgno wrote:Xform wrote:That is very interesting it worked perfectly for you in Czech Republic. Does this have to do with the United States and its magnetic field differences?
I did recalibrate the unit more then once.
Envoyé de mon iPad en utilisant Tapatalk
Posted: Tue 23. Oct 2018 13:54:06
by urgno
then maybe there is a strong magnetic field next where you fly
Posted: Tue 23. Oct 2018 14:41:25
by Xform
I recalibrated my Geolink many times. Interestingly, when I go home and view the geolink map, the geolink shows exactly where I am and it is very accurate. It just has problems while flying, but otherwise, it shows my location on the map really precisely.
I was thinking maybe something different about the Czech republic makes the geolink work better there? I don't know.
Posted: Tue 23. Oct 2018 15:16:05
by urgno
maybe is that i am not so far like you from czech
