[SOLVED] No cyclic to left side after 2 min flt in Stab Koax
Ah, that is great.
So maybe just by disconnecting the fan it will all work well.
Could you please disconnect it for a try? It should handle also 3D flight without the fan on your model.
HobbyWing fans are unfortunately creating ultrasound that is disturbing the sensors a lot. For this reason disconnecting it it could be all solved.
tabbie
I have removed the fan. Trying again this evening.
tabbie
I have flown the heli yesterday, perfect weather.
I changed the following before the flight, removal of the ESC fan hobbywing 100A platinum, I have changed the GEOLINK to a closer position about 10cm away from tailservo. I have wrapped the GEOLINK cable with aluminium foil from a chocolade bar and grounded the foil to the tail boom.
The issue is gone, everything is good now.
(solved)
enied
tabbie wrote:I have flown the heli yesterday, perfect weather.
(solved)
I did buy a Sunon MC30100V2-A99 fan for my hobbywing 100A V3 platinum and use it. No problems caused by the fan at all.
BR Eugen
That is great! Thank you very much for the message!
