[SOLVED] Rescue is brutal
enied
This looks to me like the tail gain is too high. The heli is not shaking, just the tail.
BR Eugen
kgnkazanci
I think it's due to the negative gain of tail to activate rescue gets too high. Can you connect the heli to computer and check at diagnostics screen in order to compare what are the gain values when you hit the rescue and normal flying?
azaz44
Oh yes, this might be the reason. I send -100% to this channel when rescue is on. I wasn't aware the negative value is actually still used.
I'll change and see..
azaz44
I finally had a chance to test it in fight. It works like a charm after changing gain settings, perfectly smooth rescue. Many thanks for help.. and I wish I asked this question 200 flights ago :)
Thank you for the message!
