[SOLVED] Geolink map crashes software and other questions
rhodesengr
So I tried clearing the log and the map still crashes. I tried an experiment. I powered up, went to the map, and as soon as the map crashed, I powered down. Here is the log. You can see that there is that message about a broken connection. I think that maybe the map disappears when the connection breaks. It might be the other way around. So what is causing those connection breaks. The model is just sitting on my desk connected to my desktop.
00:00 Calibration Finished
00:10 Good Health Message
00:20 Good Health Message
00:30 Good Health Message
00:40 Good Health Message
00:50 Good Health Message
01:00 Good Health Message
01:10 GeoLink connection is broken
Here is another log. Around 7:00 I went into the Map. As soon as it crashed I opened the log. There is another Geolink broken connection message. It only seems to appear when I open the Map.
01:10 Good Health Message
01:20 Good Health Message
01:30 Good Health Message
01:40 Good Health Message
01:50 Good Health Message
02:00 Good Health Message
02:10 Good Health Message
02:20 Good Health Message
02:30 Good Health Message
02:40 Good Health Message
02:50 Good Health Message
03:00 Good Health Message
03:10 Good Health Message
03:20 Good Health Message
03:30 Good Health Message
03:40 Good Health Message
03:50 Good Health Message
04:00 Good Health Message
04:10 Good Health Message
04:20 Good Health Message
04:30 Good Health Message
04:40 Good Health Message
04:50 Good Health Message
05:00 Good Health Message
05:10 Good Health Message
05:20 Good Health Message
05:30 Good Health Message
05:40 Good Health Message
05:50 Good Health Message
06:00 Good Health Message
06:10 Good Health Message
06:20 Good Health Message
06:30 Good Health Message
06:40 Good Health Message
06:50 Good Health Message
07:00 Good Health Message
07:10 Good Health Message
07:20 Good Health Message
07:30 Good Health Message
07:40 Good Health Message
07:50 GeoLink connection is broken
Thank you for the message.
I will send you a private message.
n2wizard
I have the same problem. I just got my Sprit and Geolink a few days ago. I set up a bench test, using a spek satelite in sat 1 and geolink in sat2 and all went well until I tried the map tab on my geolink. Page showed 5 satelites, even though I was inside where I normally get none on other gps units.The geolink system crashed, menu items went gray and geolink shows disconnected. After a fresh boot up, geolink gives a series of random blinks, then settles down to a series of one blink. Will not connect How do I revive my geolink, and how do I prevent this from happening again?
Herman
it look like your GeoLink is in calibration mode. Maybe calibration request was engaged in the Spirit Settings. You have to finish the calibration all in all.
Did you ever perform calibration previously?
n2wizard
I calibrated compass and got 5 satelites inside. I went to map page and the geolink crashed. I tried rescue many times with no success. How do I get geolink working?
Herman
Do you have small Spirit unit? If so, could you attach Spirit flight log from any time when connected with your computer, please?
n2wizard
Latest report
Still no success in reflashing dead geolink Connect spirit in software shows connected, ver 2.8.0
On geneal tab, check geolink, click on tab, shows not connected. Click on update, select geolink-fw 1.0.34dg. Click flash, recover. Reconnect geolink, shows steady blue light, green bar shows uploading. After bar goes to 100%, geolink light flashed, goes back to single flashes, page says update failed. I have repeated this many times. Now what?
Herman
log is empty
are you able to record short video from moment the helicopter is powered up?
I would like to know what GeoLink Status LED is doing exactly. Because this will tell us in which mode it is.
If it is in Calibration mode then the only thing you have to finish is the Calibration. If not finished properly, it will not be visible in the software.
Only when finished then it will work.
At the moment it look like it is the case. So there might be no problem in theory.
Reflashing or any other operation will not help. Only calibration must be finished to make it work (if this is the case).
n2wizard
Here is a video of spirit startup. This is a new unit, never mounted in a model.
https://www.youtube.com/watch?v=imhS_-i ... e=youtu.be
I do not know how to get it out of calibration mode. Geolink page is all grayed out except upgrade.
Herman
urgno
https://www.youtube.com/watch?v=skH0u2yV6_M
if you pressed "calibration" button
is boring but have to be done entirely ;)
