Re: Hobbywing and telemetry
Posted: Fri 05. Apr 2019 16:19:04
Don't even know why I am wasting my time to responding to you you are a bit of a troll. None of your links cover what I asked. I am not using any of those features in isolation.cracked canopy wrote:
Spirit has gone to great lengths to write a very complete manual. Here are 3 links that could have answered your questions.
http://manual.spirit-system.com/index.p ... ntegration
http://manual.spirit-system.com/index.p ... RPM_output
http://manual.spirit-system.com/index.p ... _Telemetry
Nothing in the integration link says the plugs can be moved. Nor does it explain the reason the data pin is plugged into the AIL pin and not any other data pin. What's the significance of those pins that makes them different then any other data pin?
The RPM link also does not cover use of RPM with telemetry. So your completely missed the point. And again why the PIT pin and not any other data pin. What's the significance of that pin?
The hobbywing telemetry link says nothing about what you plug you primary sat into after you use the primary sat port for telemetry.
So the links do a decent job of explaining how to connect things in isolation which is NOT what I was asking. They don't do a good job of explaining when you want to combine things together. You contributed absolutely nothing this this thread. Which is pretty much the definition of a troll.
Helpful thanks. Do you explain anywhere that the ELE/PIT/AIL pins are bidirectional data pins? I did not find it anywhere. If it's not documented that would be useful to document somewhere.ZeXx86 wrote:Yes, you are right. AIL pin can be used for bi-directional communication, for this reason it is used with the receiver.
Spektrum Satellite can only send data so the RUD port can be used.
There are few options how to connect it all together. The only thing you have to do is to connect each thing step by step, not all together.
If you are proceeding step by step, then our guides will explain how to connect everything in the end.
Can any empty port be used for the spare sat or does it need to be specifically the RUD port?
Your guides do a decent job of explaining individually. But they don't do a good job of explaining how the features can be combined.
