Page 2 of 2
Re: setup problem
Posted: Fri 14. Nov 2014 23:12:20
by The Mechanic
I would like an exchange actually as most people really like the Spirit and I think I will too. I do trust you and tried all your suggestions but as I said I don't use DSM2; it should work fine with DSMX. Please give me the return address you would like shipped to.
Re: setup problem
Posted: Fri 14. Nov 2014 23:14:54
OK, you should receive private message.
Address is also mentioned on the box of the unit.
Re: setup problem
Posted: Fri 14. Nov 2014 23:16:47
by The Mechanic
Oh, and I was going to ask, maybe you missed in previous post; is it true that all ports except ELE/PIT/AIL and SYS share negative and positive bus? You should be able to plug 5V power into any port except ELE/PIT/AIL and SYS?
Re: setup problem
Posted: Fri 14. Nov 2014 23:20:07
Yes, it is true.
Re: setup problem
Posted: Fri 14. Nov 2014 23:24:32
by The Mechanic
Thanks!
Re: setup problem
Posted: Sat 15. Nov 2014 15:12:29
by Yak
Have you tried filming the TX (with the channel outputs) and the diag screen.
The guys here really helped when I and another user ran across something very weird.
Have you a full RX (not sat) that you could connect with the loom to test.
Cheers,
Yak.
