Page 2 of 2
Re: Spirit Profile Viewer / Zobrazení profilu
Posted: Sun 31. Jan 2016 22:03:23
mohu, ale tak ci tak ho nedoporucuji pouzit. Jakykoli profil z jine heli by se mel pouzit spise jen k nahlednuti. Pokud je heli osazena stejne a je uplne stejne mechanicky nastavena, pak se da pouzit. I tak vice nez 3 hodnoty parametru nema cenu "okopirovat", ostatni uz jsou veci, ktere ma kazdy trochu jinak.
Jakmile je ale nekde jine servo, muze byt nastaveni uplne jine a poleti to spatne.
Spise je lepsi napsat, co zlobi a poslat tve nastaveni.
U Protose to byva vetsinou vrtulka. Nejcasteji je problem v mechanice - nejde tak jak by mela (i kdyz je heli treba uplne nova). S protosem mam hodne zkusenosti, takze mohu pomoci.
Posted: Mon 01. Feb 2016 22:13:48
by IvoR1
Díky za odpověď, přiložil jsem své profily http://www.spirit-system.com/phpBB3/vie ... 371#p13371
Koukni prosím na to.
Díky
Posted: Tue 09. May 2017 20:25:36
by Adrian
reports unsupported for version 2.4
Posted: Mon 10. Aug 2020 12:21:38
by stefaanbolle
I am using a Spirit Pro with Geolink and an SRXL2 4651T receiver.When uploading the 4ds file on the profile viewer beta webpage, I get belo error:
Code: Select all
index receiver_values and value 6 not found
Is SRXL2 not yet supported?
Posted: Sat 15. Aug 2020 18:11:33
by stefaanbolle
Is there a problem with reading the file when using a SRXL2 type receiver? Where do I have to report a possible bug?
Thanks!
Posted: Sat 15. Aug 2020 22:50:27
we will try to sort it during next week. Thank you for your patience. Unfortunately we are still extremely busy.
Posted: Sun 16. Aug 2020 7:39:38
by stefaanbolle
No problem!
Thank you very much for all the great work!
Posted: Wed 23. Jun 2021 17:09:44
by MichaMEG
unfortunately, this no longer works with the current version.
The following message appears:
Unsupported version: heli-3.2.1
I would be happy if you would update the tool!
Thank you very much
Micha
Posted: Tue 25. Jan 2022 18:40:00
by chinook
Error still shows, any chance you can fix this?
Posted: Thu 17. Feb 2022 20:48:45
we will make completely new viewer. It will work with all versions without error.
