Page 2 of 2
Re: Diabolo Setup?
Posted: Tue 26. May 2015 15:26:53
by smsodhi
Hello, these are my Diabolo setup files for all banks.
Bank 0 is the main bank, I have not done a lot of work on the others, but bank 2 is set up with a harder and faster feel.
Re: Diabolo Setup?
Posted: Sun 20. Sep 2015 0:13:58
by gabs_mex
Is this for a 550 or 700??
Re: Diabolo Setup?
Posted: Wed 21. Oct 2015 21:53:35
by ChrisTTian667
I would be interested in Triabolo 700 Setup too.
I will use the Spirit Pro in the Triabolo, but i assume that makes no difference to a normal Spirit, right?
cheers,
Chris
Re: Diabolo Setup?
Posted: Thu 22. Oct 2015 8:34:42
Settings should be similar, altough configuration of the rotation rate, cyclic gain and cyclic feed forward may be different to achieve similar behavior.
Re: Diabolo Setup?
Posted: Tue 27. Oct 2015 9:15:27
by aziz76
When you say similar, are you talking about Diabolo 700 and Triable 700? Or Di 700 and 550?
I am looking for a file for the Diabolo 550.
Re: Diabolo Setup?
Posted: Tue 29. Dec 2015 3:55:30
by fernieheliman
I had a Spirit on my Diabolo for a while now , I have to figure out how to post it here ...
or what parameter do you need to know ?
Re: Diabolo Setup?
Posted: Tue 29. Mar 2016 17:24:08
by ChrisTTian667
It would be awesome, if Tomàs could add Di-/Triabolo Presets in the next version of the configuration tool. :)
I added my settings for the Triabolo. The Rescue function is not enabled via Bank-Switch but will be enabled via two -100% Mixer in my Jeti DS. I prefer that because the rescue will always work with correct tail gyro settings. I only use the different Banks to switch between different Rollrates.
Tail Gyro is also set via TX.
Idle 1 75% - 1200rpm
Idle 2 70% - 1400rpm
Idle 3 65% - 1800rpm
best regards,
Chris
Re: Diabolo Setup?
Posted: Mon 29. Aug 2016 19:45:08
by gabs_mex
ChrisTTian667 wrote:It would be awesome, if Tomàs could add Di-/Triabolo Presets in the next version of the configuration tool. :)
best regards,
Chris
+ 1 to add as preset on the software 550 - 700 Di/Tri
Re: Diabolo Setup?
Posted: Mon 29. Aug 2016 23:17:20
by kramrle
+1 yepp that would be great
Re: Diabolo Setup?
Posted: Tue 06. Sep 2016 3:16:37
by markrj
+1! Would love to see Minicopter and MSH Protos Max V2 settings.
