Questions about F3C Setup (Spirit 2)
- heliflieger8587
Here my settings for the Goblin 700.
- Attachments
- kunstflug.4ds
- (255 Bytes) Downloaded 357 times
Thank you very much for the video.
If time will allow tomorrow we can prepare special firmware for you. It will be interesting to see if it will help.
So we can make it perfect for F3C. Then it can be embedded in official firmware later.
- heliflieger8587
Hello Eric,
it depends on how hard you fly the curve. If you make a big bow, the problem does not occur, or only minimally. If you fly quickly with a small radius, this effect occurs.
When the candle goes out this is e.g. not disturbing, because you have to take your nose down anyway to pick up speed again.
greetings Björn
greetings Björn
here it is:
http://spirit-system.com/dl/fw//spirit-fw-3.1.32.4df
No need to change anything in the settings.
here it is:
- heliflieger8587
I am currently on the flight field and test your new version.
I must unfortunately say, that the effekt is also present with this version.
I think not so hard, but with a higher rpm my goblin flip about 15°
Have you any ideas, what we can do next?
Bjoern
Bjoern
Hello
I can confirm this problem
I was flying today and I have the same behavior 15°
Thomas
Thomas
official hacker distributor USA
www.hackermotors.us
www.hackermotors.us
here is what I experienced with the special firmware:
The first candle I flew had the same effect like before. The following candles the tilt became less until it was nearly gone.
But the firmware also caused other unwanted behavior. First of all it feels less stable while cruising and in straight passages. When I steer pitch while flying forwards the heli does an additional nick-movement, so that it flies in shape of a wave.
Beside the "candle-problem", I also still have a bouncing after cyclic input, regardless of the new firmware. Setting the Elevator Filter to 4 helped a lot. So I wonder if it would be possible to increase that damping-effect (like a value of 5)?
Great thanks for your effort!
Frieder
Frieder
in that case the problem seem to be something else.
Can you verify what will be result when Flight Style is set to 1?
