Page 2 of 2
Re: Strange Rescue Behavior
Posted: Sat 16. Jan 2021 20:51:37
by swash23
swash23 wrote:No problem, we have been in contact and I always got a fast reply.
But the issue was not fixed or identified. I can reproduce it even after doing 1 min. of flips.
And sometimes rescue turns the heli and rescues towards the ground (Gives you a rush when it does that
I tried every combination of 'Ext. signal processing' and 'Stabi correction'.
Vibration was low (20-30)
Just a quick update on this. I have been in contact with Thomas and we have been able to get it to work.
I am now able to do the flips and hit rescue afterwards without any issue.
Thanks Thomas for the great support.
Posted: Sat 16. Jan 2021 21:02:39
by cracked canopy
swash23 wrote:swash23 wrote:No problem, we have been in contact and I always got a fast reply.
How about sharing the solution ?
Posted: Sat 16. Jan 2021 21:25:53
We added calibration for Gyro sensor, which help to eliminate tolerances from manufacturing process.
After calibration precision can be improved noticeably. Fortunately it could be really needed only in rare cases, if so it is done once for unit.
So if precision is still not good after trying all options, this can be possibility.
Posted: Sun 17. Jan 2021 0:28:09
by jjuk
So is this automatic or do we need a software update? I've had rescue towards the ground in the past but there was no solution.
Posted: Sun 17. Jan 2021 8:56:58
This depends on when the problem was happening. If firmware 3.1 and newer was used, then there are new possibilities to resolve the problem.
If you tried to proceed according our guide with no improvement, then you can use this new solution. It will be available in the new update.
Posted: Tue 19. Jan 2021 6:59:13
by TomazBernik
This is good news as my unit wants to throw heli into the goround sometimes after advanced manouvers too (running 3.2.1 firmware). Now I see that I'm not such a lonely case with this problem, people started to chiming in on this issue.
Looking forward to next firmware update!
Posted: Mon 22. Feb 2021 22:18:19
by Bill-kraken-700
Where can this gyro calibration settings be found ?
