Bailout and tail
thekarma
I'm being stupid but how do I set the gain to negative on the sensor tab... All I have is sensitivity (Cyclic and rudder common gain, both positive). Reverse and rotation speed...
After unassigning Gyro Gain function in General/Channel Assignment it will be visible in Sensor Tab. It is hidden now.
Yogi43
ZeXx86 wrote:If you want to switch between conventional flight, stabilisation and rescue (with only one switch on your TX), you can do so with unassigned Gyro channel, so you can configure Gyro Gain (in the software - Sensor Tab) to negative positions for Bank 1 and 2, but for Bank 0 it will be positive.
So activation will be performed with Bank switching only, but Gyro Gain will be configured in the software.
There is also the possibility to switch the GyroGain to negative by using a mixer on the same switch used for the banks. I have done so - it is working great.
Gesendet von meinem GT-I9515 mit Tapatalk
